bclapham
- Nov 5, 2001
- 4,340
- 0
OK, i am having a lot of fun getting this 02rm144 really dialed on the jettting and it seems like everytime i ride it, it just gets faster and runs better!
However, i still feel there is room for improvment, and i think i need to go leaner still from 0-1/2 throttle positions- it might be the v-force and the bigger bore making it run rich.
so i have two areas to work on, 1. pilot+slide and 2. needle+nozzle.
1. pilot- i have the smallest pilot (25) and have cut the slide ~0.75mm, the bike is still rich and the idle/peakrev method with the airscrew is peaking around 3 turns so i know i am still rich here- Can i cut the slide a bit more (~0.5mm) to get this circuit back on track or are there any pitfalls to going to far? it ran loads better with this mod btw.
2. I started the day at the 3rd clip of the stock needle and it was loading up a bit. i went to the leanest posn and it was loads better. then i went to the next leanest needle (0.02mm wider) (infact the leanest suzuki needle you can get) in the 3rd clip and it was not as good(rich)- then moved the clip to the top and it was even better.
so here is my predicament, i am at the leanest needle setting i can put in there, will a smaller nozzle be in order here, or can i find a differenent needle series to help both the 0-1/4 and 1/4-1/2 throttle positions?
btw- i am now much happier with the main, no more detonation since i think compression and too close a squish clearance was hot helping there.
sorry for the long questions, thanks, BC. :thumb:
just to add a bit more info, i opened up the carb tonight and took out the nozzle, however, it has no markings on it so i cant identify it- i wonder if it is the S-9 though similar to the yz's??
also, i noticed from the manual that the needle OD only really effects 0-1/4 throttle, so this again send me in the direction of a different nozzle but which one, LOL!
