Info on stroking
Discussion in 'Fabrication, Welding, Machining' started by MikeS, Sep 26, 2002.
  1. motometal
    motometal Lifetime Sponsor
    Sep 3, 2001
    2,688
    36
    if an engine with a given stroke gets the rod replaced with a longer one, and the piston dwells at tdc and bdc longer, isn't it logical that when the piston does start moving towards the other end of the stroke it would accelerate faster? It has less time to travel the same distance, gotta make it up somehow!
  2. MikeS
    MikeS Lifetime Sponsor
    Jun 12, 2000
    754
    Hey wfo
    Getting back to the specific info on the RM85. I have my cases setting in front of me. There is atleast 3 mm ++ of room between the Rod big end and the cases so adding 3.2 mm stroke it will move the rod 1.6 mm closer to the cases. No Problem as you still have 1.4 mm plus . The crank itself is about .060" from the case. I am curious as to what some of these guys use epoxy for in the crankcase as there is not much room as it is.
    This thread has atleast given some good information plus raised more questions....Piston speed, ring design, Exhaust waves, Rod length, Crank balancing etc....
    Eric maybe you should write another book for the advanced subjects :p
  3. Jon K.
    Jon K. Subscriber
    Mar 26, 2001
    1,470
    38
    Ahh!! 3mm clearance. There you go! Thanks Mike.
  4. EricGorr
    EricGorr Super Power AssClown
    Aug 24, 2000
    790
    motometal
    Yes you're right. Two things are happening when a longer rod and increased stroke are added to an engine. The piston dwells at TDC longer and enables the combustion pressure to increase before the piston accelerates down the bore with the added leverage affect. At BDC the rod spends less time so it can cause the reeds to open further and change the timing and duration of the intake phase.
    Sometimes these things make a big difference, sometimes they fight each other because it throws something else out of sequence. The point in my article is that stroking or boring doesn't always produce more power. Some engines like KX85,100 benefit from stroking but not boring. Some engines like the KTM65 lose with either mod. It just takes trial and error testing to determine what works best for what rider in a given soil type and terrain obstacle.
    The "What's All This Fuss" title sort of pokes fun at the tuners who are trying to rev up the consumers with exaggerated claims of what stroking can accomplish, other than fill their pockets with more cash.
  5. cr-man
    cr-man Lifetime Sponsor
    Nov 6, 1999
    343
    I called and talked to crank works on the balance of stock cranks to find out where the manufacturer's stood on their balance and they told me Honda is the worst Yamaha and Suzuki are middle of the road and Kawasaki is the best as far as balance from the factory! I thought this was pretty interesting and thought I would share this info.
  6. marcusgunby
    marcusgunby Lifetime Sponsor
    Jan 9, 2000
    6,590
    Ive often wondered if the vibes when riding the alloy frames on the honda could be made better with rebalancing the cranks.
  7. cr-man
    Nov 6, 1999
    343
    I sent my crank out to crank works for balancing Marcus when I find out I'll let you know if it can help?
  8. motometal
    Sep 3, 2001
    2,688
    36
    i'm a little foggy on the details of balancing, but I believe it's only possible to balance the engine for a certain range of rpm. In other words, in the case of my Honda, it's apparently balanced around the powerband, and not-so-balanced at low rpms. From my experience, Hondas and Kawasakis have the most vibration on their 250s.
    I have to chuckle a bit at the piston ads I have seen bragging "lighter weight than stock"...wait a minute...wouldn't you have to re-balance the engine?? :|
  9. marcusgunby
    Jan 9, 2000
    6,590
    CR man i would like to hear how it works:)
  10. hot125mod
    hot125mod Rookie DRN Member
    Jan 14, 2007
    501
    hey eric i have a mini dad friend that swears by putting a 52mm piston in his sons 05 kx 85 making it a 103 I think correct me if I am wrong. Now he got an idea to put a 54 mm piston in it. The water jacket must be so thin it seems like he fried it about every weekend and he had the pwr radiator on it too. Part of it is that he is a dumbass and ignores the fact that warming up his bikes before his kids ride is something that shouldn't be left out they locked a motor up faster than you can say "Wow that guy needs to not spend so much time drinking and pay attention to his bikes". Can't wait to hear from you. Thanks again. We all appreciate your wisdom and many things you have done for our sport. Keep on doin what you do best. YOU THE MAN ERIC. :)
  11. hot125mod
    Jan 14, 2007
    501
    what do you think Eric? :nod:
  12. hot125mod
    Jan 14, 2007
    501
    this is from a while ago but i want to know others opinions.
  13. hot125mod
    Jan 14, 2007
    501
    could you get the same peak power from a good 125 mod as you could a big bore 134 or 139 or is it not possible. cant seem to remember but a 134 and 144 make the same peak power the 144 is just a lot more broad
  14. hot125mod
    Jan 14, 2007
    501
    Is there any off the shelf pipe you could use for a stroker motor or long rod or not because these 2 change the timing too much?
Similar Threads: Info stroking
Forum Title Date
Fabrication, Welding, Machining Info on stroking Sep 26, 2002
Fabrication, Welding, Machining Some info for you Race gas users Jun 21, 2005
Fabrication, Welding, Machining Rich, Info on Nutec fuel! Apr 4, 2002
Fabrication, Welding, Machining Information for Research Paper Mar 22, 2002
Fabrication, Welding, Machining Info for Rich( Boron Nickel ) May 25, 2001
Share This Page
