Is push starting the bike bad for the transmission?
Discussion in 'Bike Mods, Performance, Maintenance & Repair' started by thouston1111, Jan 18, 2006.
  1. thouston1111
    thouston1111 Rookie DRN Member
    Jan 18, 2006
    i just got a 97 honda cr 80, not really used to clutch, i had a quad but i just shifted with my foot there was no clutch, so the bike is kinda new, but going into first i bog out alot, i know you have to practice to get it but im kinda of un patients, so i push sttart it in first gear cause im kinda un pateint, is that bad for the bike?
  2. Sub
    Sub Rookie DRN Member
    Nov 19, 2004
    36
    It won't hurt the bike, but i recomend bumping it into 2nd gear not first. It will start easier that way. I bump start my bike all the time if I'm on a hill.
  3. FruDaddy
    FruDaddy Member DRN Member
    Aug 21, 2005
    2,859
    36
    Last weekend, I spent about 5 minutes explaining how to operate a clutch to my 10 year old daughter. Sure, there were a couple of stalls, but she got it. Just work on starts for 5-10 minutes per day for about a week and save yourself the hassle of pushing our bike up a hill so you can start it.
  4. cookiemuncher
    cookiemuncher Rookie DRN Member
    Jan 19, 2006
    4
    it's not bad for the bike, like the other guy said don't do it in first, do it in second or third, the motor has to spins at a higher rpm in first for a given speed so it's harder to do and easier to lock up the rear tire.
  5. nickyd
    nickyd Rookie DRN Member
    Sep 22, 2004
    873
    its not bad for the bike but damn dude, a clutch isn't that hard to operate
  6. TimberPig
    TimberPig Rookie DRN Member
    Jan 19, 2006
    859
    If you do it enough, it will eventually cause some wear and damage, but in the short term it will be fine. Learning to use the clutch will benefit your riding in the long run more, so as was mentioned, practicing using it to take off is worth some time spent on it.
  7. Someone
    Someone Rookie DRN Member
    Mar 12, 2001
    865
    I think the bottom end is under much more stress when the bike is running, in gear and accelerating versus a simple bump start. Shouldn't hurt it at all.
  8. Agitator
    Agitator Rookie DRN Member
    Dec 21, 2005
    210
    IF you wanna' learn the clutch, and you're bogging/stalling, just let it out AS SLOW AS POSSIBLE, so you can barely see the lever move (have low-moderate throttle)... in like five tries, you'll get the hang of it... just go REAL slow...
    Good luck man~
  9. ellandoh
    ellandoh dismount art student Mi. Trail Riders
    Aug 29, 2004
    3,221
    36
    if you begin bump starting it repeatedly for 8 hours a day you will have gray hair before you wear anything out but yourself
  10. clash365
    clash365 Rookie DRN Member
    Jan 19, 2006
    yes it will hurt it because you need to let the bike warm up be for you take off on it let the oil get on the topend of the cluch
  11. ellandoh
    Aug 29, 2004
    3,221
    36
    wrong
  12. JST122
    JST122 Rookie DRN Member
    Dec 29, 2005
    651
    Just take 30 minutes and practice starts, and then you wont have to worry about this issue anyway because you will know how to use the clutch. Stall it a few times and before you know it you will have the feel.
  13. Agitator
    Dec 21, 2005
    210
  14. MONKEYMOUSE
    MONKEYMOUSE Subscriber
    May 10, 2001
    891
    I love when people chime in with ridicules answers lol. First there is no "top end of the clutch" second its a 2 stroke the oils in the gass for the top end and third the clutch is always saturated in oil, your answer now matter how interpreted is wrong lol sorry. No it wont hurt a thing but urself from pushing it.
  15. Someone
    Mar 12, 2001
    865
    I think he meant that since the bike isn't warmed up, it *could* do damage by bumping it cold, then taking off without properly warming up the bike.
  16. MONKEYMOUSE
    May 10, 2001
    891
    Well yes ripping a cold bike no matter how its started isn't wise but he was asking if bumping a bike is bad, there for why would he be talking about ridding a cold bike? He also said that it was bad to bump the bike because it wasn't warmed up yet, that's irrelevant. But any who it doesn't matter just a simple mistake/ misunderstanding between people.
  17. OldTimer
    OldTimer Rookie DRN Member
    Feb 3, 2005
    475
    When I was teaching my son to start off using the clutch, I told him to try to go about two feet and then stop. It helps avoid that last second clutch lever release. It really works like a charm. Just ease out on the clutch until the bike starts to move, then pull it back in and stop. Do this about five or six times (it only takes a few seconds). And you'll get the hang of it almost right away. Even now, when I see him getting a little quick on the clutch, I have him do this two or three times and, voila, back to normal.
    Try it!
  18. kwiktsi
    kwiktsi Rookie DRN Member
    Jan 20, 2006
    13
    I think that is the point- the guy is trying to push start the bike and just take off from a roll to avoid using the clutch. If he just pushes it and takes off, I'm sure he'll be riding it cold also which, obviously, isn't good for the top end at all. Learn to use the cluth, it's not hard at all with a little practice. I think it took me a day to learn without stalling or anything waayy back when I was 7. This could be a safety issue also- if you are too impatient to even learn to use the clutch, how good are your actual riding skills? I dunno, maybe it's because I'm older now, but I feel if you don't want to take the time to learn something properly- especially something that could hurt you- don't do it at all.
    Joe
  19. Someone
    Mar 12, 2001
    865
    You quoted the person saying it was a dumb response, and he was talking about bumping a COLD bike, now you're agreeing with it. ;)
  20. tracetrimble
    tracetrimble Rookie DRN Member
    Oct 20, 2005
    75
    I recommend learning to clutch, and spending more time in English class. :p It will start easier in 2nd if you do bump start it, and it won't hurt anything in the tranny.
Similar Threads: push starting
Forum Title Date
Bike Mods, Performance, Maintenance & Repair KX250F 2012 Push Rod Assembly Jul 1, 2014
Bike Mods, Performance, Maintenance & Repair 105SX pushing out left crank seal... What gives? Dec 10, 2010
Bike Mods, Performance, Maintenance & Repair How to change lower push rod bearing?? Nov 13, 2007
Bike Mods, Performance, Maintenance & Repair Suzuki Clutch Rebuild RM125 Push Rod May 23, 2007
Bike Mods, Performance, Maintenance & Repair 1981 yz250 clutch push lever assy. ?? Jan 2, 2007
Share This Page
