KDX hybrid build......
Discussion in 'Canadian Daves JustKDX' started by HRDROKN, Aug 24, 2010.
  1. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    Worked on the exhaust mounts....
    [​IMG]
    A little extension here should cover it...
    [​IMG]
    Will start on the silencer....
    [​IMG]
    [​IMG]
    :whoa:
  2. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    I was able to get a little work in on the exhaust this morning. I used the FMF KX 125 silencer with the FMF KDX internals and stinger cut to fit...
    [​IMG]
    [​IMG]
    [​IMG]
    :nod:
  3. _JOE_
    _JOE_ Subscriber
    4,700
    36
    Aww dang! You're almost ready to rock!
  4. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    I've been slacking on the updates....
    Finished the exhaust mounts.
    [​IMG]
    [​IMG]
    Exhaust completed...
    [​IMG]
    :nod:
  5. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    Electrics all mounted....
    [​IMG]
    [​IMG]
    :ride:
  6. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    Lower radiator crossover hose just clears head stay mount...
    [​IMG]
    With the motor sitting in the forward rotation the return hose is against the motor, so I will just have to keep an eye on it for wear...
    [​IMG]
    :whoa:
  7. kawaJawki
    kawaJawki Rookie DRN Member
    Jul 17, 2001
    9
    Let me know when you want to sell this bike.
  8. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    I'll let you know when I get a KX roller ready to go with swingarm and mounts complete...
  9. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    And I she lives..I rode her around a bit today. I already feel the difference with the Ron Black mods. With the same jetting, the motor feels to have more bang through its range and it even feels like it lugs better. I suspect the top end will not have changed much with a woods pipe on,but the gears roll quicker with the new found acceleration.
    I still have a few things, including replacing the the left side radiator... before hitting the trail.
    [​IMG]
    [​IMG]
    :nod:
  10. _JOE_
    _JOE_ Subscriber
    4,700
    36
    Damn nice work! That thing looks factory for sure. I bet it's a blast to ride, would probably be great on the track for any of us slow guys who like the bottom/mid...
  11. Joburble
    Joburble Bring back the CR500
    Jul 20, 2009
    417
    16
    Dear Mr Kawasaki over there in japan, build us this and we will buy it.
    Stunning work HRDROKN :cool: :cool:
  12. BSWIFT
    BSWIFT Sponsoring Member<BR>Club Moderator N. Texas SP
    8,160
    7
    38
    Congrats! Well done.
  13. antonyp
    antonyp Member DRN Member
    Jun 20, 2002
    53
    6
    Pafos
    I want one :nod:
    :cool: :cool: :cool:
  14. johnnymoto
    johnnymoto Subscriber
    Nov 9, 2000
    89
    Truly are impressive work of art backed up with very good talent. Congrat's. MY 92'kdx will never look the same now, thinking on how it should be made. The high end chopper building boys have nothing on you. Good Job!
  15. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    Thanks for the comps guys!
    So I did have a chance to get out and ride this last Sunday. I can say it’s good and not so good….
    The balance of the bike is great, definitely “feels” lighter than the KDX (not sure what the weight reduction actually is), easier to ride through the technical stuff than the KTM. As I made each consecutive loop I found myself less concerned with my lines, so it would seem that the suspension is at least in the ballpark.
    With the RB carb mods, I have the 1/8-1/3 throttle bog when whacking the throttle with the bike on the flat… tried some different known setups including what RB sent without a cure at this point. On the trial when the motor is under load the bog does not exist… other than she feels just a tad lean, but even with that she would pull from virtually nothing to WOT without complaint. I would say that the head mods have really strengthened the low to mid torque, making the bike super nice in the technical stuff.
    I have some jetting to get sorted out (after hand surgery that is) and have several things to try based on what others have found.
    Currently:
    PJ = 40
    AS = 7/8 – 1.5
    Slide = #7
    NJ = JD red #5
    MJ = 152
    [​IMG]
    [​IMG]
    [​IMG]
  16. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    If I had thought of it at the time.... I should have welded a mount for this KX100 kickstand to my frame, before I powdered it that is! Just something to keep in mind for future hybrid builds.
    [​IMG]
    :think:
  17. Joburble
    Jul 20, 2009
    417
    16
    I compiled this as a downloadable pdf incase anyone wanted to make their own hybrid and use this as a manual. I hope that's okay with you HRDROKN, if not, I will remove it.
    It's a 9.4mb download.
    >>>http://dl.dropbox.com/u/14084841/KDX_Hybrid_by_HRDROKN.pdf<<<
    I will keep this link running as long as I can but there are no guarantees.
    Thanks for your info HRDROKN.
  18. HRDROKN
    HRDROKN Subscriber
    Aug 23, 2010
    70
    6
    Great idea!!!
    :cool:
  19. Biggles
    Biggles Subscriber
    Aug 10, 2012
    29
    New to the forum
    Awesome work on the pdf, last night I sourced a 03 125 with a seized motor and have a 97 200 motor under the work bench. Project about to start....
    A quick question - the motor has no carb. Will the 125 one suitable or is it not big enough????? If not, what carb is best for a 200
  20. bionnick
    bionnick Rookie DRN Member
    Oct 21, 2012
    33
    this may be a silly question but why use the kdx engine and not just use a kx engine?, is it because the kx engine would need rebuilds more often. very nice build by the way.
Similar Threads: hybrid build
Forum Title Date
Canadian Daves JustKDX Attention KX/KDX hybrid builders Oct 23, 2006
Canadian Daves JustKDX KDX Hybrid Alloy Kick-Starter Jun 19, 2014
Canadian Daves JustKDX Another damn KDX/KX hybrid...... Sep 23, 2012
Canadian Daves JustKDX KDX's with KX forks or Hybrid Jul 18, 2012
Canadian Daves JustKDX Finshed up 2nd Hybrid Jan 9, 2012
Share This Page
