KTM 520 experiences
I am getting a 01 KTM 520EXC at the end of this March
I was hoping some of you that own one could pass along their experiences good or bad. I would sure appreciate knowing what to look/look-out for!
01KTM520EXC
91Yam WR250 4sale
86XR350
74TM125
I road my cousins 2 weeks ago,and it was the most thrilling bike I have ever riden. It was box stock except he had the forks revalved(said they were like mush on anything outside of woods riding) I mean this bike came on in ever gear. I found no faults. It was the most complete dirt bike I've ever riden.It would be my dream bike. Stock componets were first class from the hydrolic clutch to the Magura bars,frame guards,chain,etc... Congradulations!!!!!!
2001 XR250R
2001 XR400R
Shaw520
#3
xrs, keep talking like that,...you might have to change your name!
trl, Change the oil & filters after break-in (1-2 hrs), check all bolts and fastners (loctite rear sprocket bolts) Replace radiator hose clamps w/screw type (the stock ones pop off) Grease stearing head bearing. Check valves after 15-20 hrs. Keep an eye on the brake pads (they wear fast) Clean air filter every other ride. Keep good fresh gas in her, and go roost your freinds!
Congrats,...You will love this bike.
PK
On my buddy's KTM thumper, his kickstarter bolt fell out once and loosened up a few times till he loctite'd it. His exhaust springs tend to fall off also. He put some 18mm offset triple clamps on it also to help it turn better. Other than that, it's a very sweet bike.
Pat
99 YZ400
Before you leave the dealer, start it up and see if the accelerator pump has been adjusted. There have been a few posts on here about the hesitation/burp from the initial twist of the throttle. I am still living with mine (although better) after trying many different changes.
A few of the posts here stated that their dealer (if it's a good one!), should be able to cure it before getting it home.
- a d v e r t i s e m e n t -
Great bike, you will love the power band on your 520. I changed the rear sprocket to a 50 and increased the fork and shock springs to get a better ride. The valves were tight after 12 hours so check them, get the motion pro gauges 4.95 each, they are small and work great, .004 & .006.
Change oil and filters after first ride, mine were dirty, then follow your manual.
Amazing bike. Endless power that is totally controllable and completely addicting. Light and plush handling. I've never had more fun on a bike.
Other than a freak electrical short when brand new i've had no problems at all with mine. Fresh oil and filters every 300 miles and religiously check all bolts, fasteners and spokes.
Do not even think about riding the bike with the stock front tire and definitely get a Scotts steering dampener.
Enjoy it.
I guess I should have said that I am getting it used. I am buying it from the owner of a KTM/Yamaha dealership in SC. He races in 4 stroke A class in SETRA. He has sorted out the bugs that you guys have told me about, with exception of the slight hesitation in the throttle when you wick it open at low rpms. It has a Scott's dampner, and full boogie Enduro Engineering suspension, and nice guards everywhere.Clutch is a pinky finger affair (it has an easy pull lever), and it has aftermarket exhaust (Big Gun) and wide aftermarket pegs. I only got to ride it for a 5 min period as a test ride-but whatta 5 minutes!!I have been holding out to buy a new bike since my 91 YZWR, and the 520 made me pull the checkbook out. Whatta bike! I just gotta let him finish out the season, then --- I'm gone ridin!
01KTM520EXC
91Yam WR250 4sale
86XR350
74TM125
SFO
Lifetime Sponsor
my riding buddy has an 01 520xc....
his cam sprocket bolts came out...
I guess this is a husaberg legacy.
He did a steering dampener and tires too.
wrench
'00 Flappin' Fender [Ret]
Thanks Shaw, just what we needed to hear!
trl junkie,
When boy? ...... WHEN!
Very soon, Wrench! Just make sure that custom billet chest protector you special ordered is on tight next time we ride!!
I will probably get my Katoom before Spoker Ace gets his throttle stop back on his WR250!!
[This message has been edited by trl junkie (edited 03-07-2001).]
wrench
trl,
I don't know if that Chest Protector will be ready in time ..... I can't seem to find any Byrillium(sp). I guess I'll have to opt for the Titanium model!
As for Spoker Ace's throttle stop .... I went to his place last night to take care of it for him (the WR is still filthy from the first ride!). Can you believe that the boy did not have a single measuring device in metric increments?!?!?!?! I just finnished cutting it down this morning, will get back down ther this weekend, so .......
Take those God ^&%*m Banana's and......
WHEN BOY?.....WHEN?!!
wrench
[This message has been edited by wrench (edited 03-08-2001).]
Keep the chain at the correct sag. Buddy of mine has exploded two rear hubs and we think it was from improper chain adjustment.
Conga10
Wrench , You kill me!!! I do believe Spoker Ace won the "When, boy, when? " award for 2001..A brand new bike with the mud still on it????? Did he try to get ya to wash it while you were wrenching fer him? We will have to give him a good AARC team roost--Then he will need the chobham M-1 Armor bodysuit--LMAO!!
P.S. Get your s*%@^ together, before I send you off to military school with that G.D. Finklestein Sh*% kid!! heehee
01KTM520EXC
91Yam WR250 4sale
86XR350
74TM125
Have a look at the "KTM euro bike"post page 8 ...good info there !!!! By the way i just love mine !!
mechantloup
GRRRR!!!
KTM 520 EXC 01
Japanschrott?!Nein danke !!!
