Rockymountainatvmc.com - Dirt bike & ATV parts
KTM's motors
I would like to know who does all the motor work for the supercross team ?
- a d v e r t i s e m e n t -
Is there any way you can find out any of the specs? Because i was told there super fast than stock.
I am informed that they use SXS parts available from KTM, kinda like Yamaha has their YZR stuff.
01KTM520EXC
91Yam WR250 4sale
86XR350
74TM125
Yes, they do use the SXS parts right from the factory. They keep a watchfull eye over these parts and they are quite "tight lipped" regarding the specs.
So are the internals all stock such as piston, carb, and electronics? Also who imports the Doma pipes. Since your the man with the master plan.
You can get the Doma pipes right through KTM Hard Equipment 2001 #SXS.00.125.501 and #SXS.00.125.551. The motors use different cranks, pistons cylinders, heads, carbs and transmissions. (whats left?) I believe the electronics are also changed.
Thanks for all the info. I'm just trying to make a fast bike for an intermediate(my little brother).If you do know what they use that the normal man can get.
