pradami said:How do i jet the bike right?? should i take it in to a dealer to do? or is there a way i can do it myself? What needs to be done on a top end rebuild and how much will that cost me about?
pradami said:any other tips?
Jetting depends ALL on whether the bike is stock or not, elevation, temp., etc.micshol said:jetting depends alot on whether the bike is stock or not, elevation, temp., etc.
Doing a top end when it is needed and BEFORE there is damage will take around two hours.
pradami said:Yea those links are extremely helpful thank you. If i have an air filter, should i reuse the same one? or replace it everytime i need it "cleaned" If i don't need a new one what should i do to clean it? I think it means i take off all the oil using a filter cleaning solution and then re-oil it right? just wondering. Thank you
Solid State said:snb73,
You must have alot of cracks in that driveway!
