Hey guys,
I just got done installing a '96 YZ80 engine into my YSR50 but it has problems shifting. The bike will go into first but will not go into 2nd or above. I took the side cover and clutch assembly off to get to the shift shaft.
Everything looked fine but it seems there is not enough movement to physically turn the drum. I removed the shift shaft and I can spin the drum by hand with the rear tire spinning. It then gets into all 6 gears quite easily.
I'm thinking it has to be the shift shaft but it doesn't look bent. Here is the pic of the assembly. Maybe you guys can spot something I'm missing. Thanks for the help!
