Off Camber & Sidehills
When riding off camber/sidehills should I weight the downhill peg?
Rick Fuller
  '00 YZ426
  '81 490 MAICO
RM_guy
Scared of DirtWeek<BR>Club *********
#2
Yes, weight the down hill peg. I hate off cambers but they can be mastered with smooth throttle and clutch control. Look for a rut or something for your wheels to catch on and don’t make any aggressive moves or you will slide out.
Good luck
Did I do the double?
Ah,um...Sure did. I was right behind you!
My Pictures
wardy
2005 Lori Nyland Award Winner
#3
wieghting the outside peg is only part of the trick. you should amplify your whole body weight so that you are "pushing down" on the bike as you go around an off camber corner. throttle control is critical and added weight to the nose is needed to.
main thing in a corner like that don't be afraid to lay the bike into the corner as your pushing down, but make darn sure you keep your knees out from under the bars in case you wash the front end.
wardy
"don't wake me.......I am working."
TexKDX
Subscriber
When traversing an off camber surface, uphill, downhill, or straight across, you weight the downhill peg AND lean the bike into the hill. This helps it bite and also fights the bike's natural tendency to go down the grade.
When making a turn on a off-camber grade, you will weight the inside to get the bike to start to turn across the hill, then shift your weight to the outside as described above. Same for getting it to turn on up the hill - give it a little uphill peg to get it to turn up.
TexKDX.
[This message has been edited by TexKDX (edited 03-25-2001).]
wayneo426
Location
Sandbar, NY
#5
TexKDX: Ditto.
When I used to ride off-cambers, and sidehills, I would always make the mistake of leaning into the hill without weighting the outside peg. Ive since become very comfortable countering the hill side of the bike while giving a good amount of weight to the outside peg.
Really awesome when your digging in and getting good traction. :D
2001 WR426F
"Wherever you are, be there."
Thanks for the response.
Rick Fuller
  '00 YZ426
  '81 490 MAICO
