We have a Suzuki 1990 RM 125 - What is the Best way to set up the Power valve Knob on the left side of the Block (it has a spring in it and you can turn it in for more Pressure or out for Less :ride:
You should start at the stock setting which could be about a 1/4 turn after the spring catches. If you adjust it so that it is tighter into the spring, it'll take longer for it to kick in, keeping the hit later. On a 125, I wouldn't suggest having it hit later, I'd go with a softer setting so it hits early and you get the power available. Try and play with it to see the difference and set it where you like it. ;)
