robwbright
- Apr 8, 2005
- 2,283
- 0
Last night at the race, my transmission/clutch side of the motor was REALLY hot to the touch. I could literally feel the heat through my Tech 8 in a 4 lap heat (maybe 1:20 per lap - it's a small track). My father in law stated that it was hotter than his CR125 kart after a 30 minute moto running at up to 125 mph.
Outside temps ranged from 75 degrees at the start of the evening to the high 50s at 9:00 PM.
Mobil 1 20w50 tranny oil with maybe 4-5 hours on the oil.
Coolant level is fine. The rest of the motor seemed normal temp.
Any ideas of cause/solution? Something is clearly different from the last race.
Also, my bike will hit neutral 50% of the time going from 2nd to 1st. Do you think a different weight oil would minimize that problem?
Rob
Rob
