Reed spacer on 360
Anybody using a reed spacer on a360? My bike is a 97 which is somewhat different than the 96.It has a wiesco piston boyesen pro reeds and a turbine core silencer also I had a decompression hole drilled in the cylinder. The bike runs strong but I'm looking for a smoother hit.I have it jetted spot on for the area and conditions. Thanks , Andy 360mxc
Strick
Lifetime Sponsor
Is that reed spacer, or Speed racer??
Hey Patman did 'ole GSR take you up on that offer??
Strick '99 KTM 300mxc, AMA & BRC member
ktmboy
Subscriber
I've got a '96 360, and I'm curious how that decompression hole affected you bike ID? Does it smoothe out the bottom? By the way, I like the hard hit!
The decompression hole keeps it from surging when you chop the throttle and also cleans it up on the bottom.The 99 on up 380's come with the hole.I also like my bikes hit but on tight single track trail it can be a bit much after riding 50 miles.My gearing is 13/50 I've also used 14/50 and stock 14/52. 13/50 works great for HS.
ktmboy
Subscriber
Thanks for the extra info ID360mxc. Am I correct in assuming 13/50 is quite a bit taller than stock? How does this affect your gear ratios? I've got an EXC, and I assume this would give me maybe another 5 M.P.H. on top? (not that I need it!). Does the higher gearing make first gear more usable? Sorry for all the questions, I just like hearing from someone that has already done the mods!
Thanks!!!
13/50 is lower than 14/52. With the MXC gear box the gearing is very tight but on a single track trail you can use second and third alot more.14/50 works real well out in the dez.I also shortened my FMF turbinecore about two inches and with the wiesco piston and pro series reeds it comes on hard.I think my next bike is going to be a 300 EXC maybe next year.I would like to keep my 360 I really like it.I was out riding last week and I blew a fork seal not to bad the seals had a couple of years on then. see ya
Patman
Pantless Wonder
I have the factory spacer on my 1996 360 and it sure improved the spread of the hit and made jetting about 10 times easier, the FMF exhaust made it another 100 times better plus made it into the fire breathing monster I knew it could be. I'm knocking around the idea of a V-Force 2 but since I'm also thinking of getting a new bike I'm in a holding pattern.
Nope Strick she didn't. Something about not being able to kick it over (wonder why
I ride, therefore I crash
KTM 360EXC
ktmboy
Subscriber
Thanks for all the info guys! No one else around here has a 360, so I've been going it alone. It's great to get ideas from other 360 owners. I did put the FMF Fatty/Turbine core combo on, and like Patman says, it makes jetting 100 times easier, and makes quite a boost in the power dept. Now if I could just get these forks dialed in!
Patman
Pantless Wonder
See the little oval to the left with "MX-TECH" in it? Check them out. I promise you will be blown away with the results, I know I was.
KTM 360EXC
