I neglected to check under the left side crank case cover and a load or dirt and debries got in :ohmy: . This seems to have eaten the seal a bit, now it leaks. Ive replaced this seal on a 91cr125 but i dont recall if that had an adjustable stator plate like this bike(96cr250). How should i do this to keep it in the same position, or mark the case where it was as a refrence? Also when installing this seal what is the best way to remove it, before i used this forked screw driver but i dont want to risk scoring the crankshaft. How far do you drive it in, and what should i drive it in w/? I have scockets and bushing drivers. Should i apply some grease to it to help it go in?
