pyromaniac
- Jun 25, 2000
- 378
- 0
I've been thinking what actually make a engine seize by too lean jetting. As i understand it, the engine get too little fuel in the airmixture. But is it because it gets too little oil or does the fuel itself lubricate the engine. Im only talking 2-stroke ofcourse.
The only way i would see it is because it get too little oil but thats not it according to many comments about jetting for example "dont add more oil it can cause the engine fun too lean and seize". But i cant understand really why it would seize from too little fuel. I think something like this. The less fuel the engine gets the less heat it produces so with enought oil in the mixture it shouldnt seize even if i gets too little fuel. I mean a very rich running engine will seize if it doesnt have any oil in the fuel right?
I've been as i have said many times before riding my 250 with the same jetting year-round with a 50 degree celsious temperature change. The bike should have been running lean and rich at that time. However it have always worked great and never seized. The reason i think i have never seized a engine in the 10+ years i've been riding is because i have always used 3 or 4% oil. Lets say you run 4% oil should you most likely to be able to run the bike leaner without seizure than a bike with only 2% oil. I have hard to believe you can seize a bike running say 15% oil (yes that bike will run).
Does 4-stokes seize of too lean jetting?
What i want to know: how much does the actual fuel lubricate comparing to the oil. Is it like 90% oil and 10% fuel or what can it be?
