Son's 02 KX65 Rod Seizeure! Advice Needed!
We just got my son's KX65 and ran about 3/4 gal fuel through it.
Then then the lower rod bearing seized to the crank! Man are we bummed. I called the dealer and he is saying no warranty, but he can call Kawasaki... What is my recourse here? Am I just out of luck?
There is debris marks on the piston top and head as well, that I presume are after affects from the bearing seizure. Also, at the lower beaaring location, one of the crank flywheels is blue from heat and the other has NO discoloration. Any ideas what caused this? Should I replace the main bearings as well because of the possible debris that must have been involved?
Thanks so much for any guidance!
