RECENT POSTS
Suspension help anybody?
After seeing all of the recent posts regarding the KTM suspension, I am set to jump in myself in hopes of upgrading.
Does anybody have any info on a good starting point? I own a 2001 520SX. My ability is vet novice and I ride mostly motocross tracks. My weight is in the area of 200 to 210lbs.
My bike is currently stock. If I go with heavier fork springs will the shock spring need adjusted as well? Any ideas on fork oil weight and height? Any help would be appreciated as I am hoping to get a "better" ride without the cost of a re-valve.
Shaw520
#2
J.Mac, IMO the forks are in more need of help, I went with .50 fork springs and I think 8.5 in the rear, I havnt got a chance to try it out yet,(still waiting on few new parts before putting it back together). For your weight you'll probaly find .46-.48 will work good in the front, and 7.5- 8 in the rear. Try to set the sag around 35mm static, and 95-100mm race. I'll post my results after this weekend, theres gonna be a heat wave,(50 degrees) hehehe!
Thanks, looking for ward to the report.
Any thoughts on fork oil weight and volume compared to stock?
Shaw520
#4
Personaly, Once you have enough preload w/proper sag, I feel that the lighter wt oil will work better 2.5-5wt at 120-125mm from top. No need to make them any more harsh w/10wt.
[This message has been edited by Shaw520 (edited 04-03-2001).]
Shaw520
#6
HIG4,That is a good informative page, but keep in mind that the air chamber only produces resistance at the last 30% percent of the stroke, to bottoming. If your blowing through the first 2/3rds of the stroke, you need higher rate springs to utilize the full stroke. IMO, anyone over 160 pnds riding aggresively, will want stiffer springs to keep the bike at a proper stance, 95-100mm race sag. Compression dampning and rebound dampning are another ball of wax.
jeb
What kind of riding are you going to do with this bike? Different setup for woods than it would be for MX/SX.
The SX should have come with a PDS3 (or maybe a 7?) so that should be about right for you in the woods. I'm sure the fork springs are stiffer, too, but I have no idea how much so. I just ordered .46's for my 01 400E forks. Stock is .42 for the MXC/EXC. I weigh the same as you and only ride in the woods. The Racetech dealer I got the springs from said he thought that'd be all I'd need so to try that first. I put a PDS3 out back right away and it seems just right to me so far.
John Brunsgaard - JEB
01 KTM 400 EXC
99 KTM 250 EXC
99 KTM 200 EXC
98 KTM 125 EXC
98 KTM 380 MXC (gone)
96 KDX 200
[This message has been edited by jeb (edited 04-05-2001).]
Shaw - can I ask where you got .50kg fork springs?? Actually a better question might be 'why do you NEED .50 fork springs? Unless you weigh lose to 300 pounds (or have done something stupid - like install Gold Valves), there should be no reason to go stiffer than a .46kg.
Shaw520
#9
Whip,
Holeshot has springs up to .54 (380pnd rider), They also have rear springs that go to 10.3
I'm 6'-1" 285 w/gear VetB.
I had .48's in my XR6 and were spot on.
The stock springs on the RFS are way soft, even for 170pnd aggresive rider. Hell, I got that by 100pnds, w/alot of upperbody weight.
Better to have high rate springs with very little preload dialed in, than have too low rate springs with alot of preload dialed in.
But,....Im having a hard time setting the sag on my PW80!
[This message has been edited by Shaw520 (edited 04-05-2001).]
