This dern oil level bolt..
Discussion in 'Big Bikes' started by KaTMandoo, Jul 28, 2001.
  1. KaTMandoo
    KaTMandoo Rookie DRN Member
    May 16, 2001
    84
    Ok this thing is about to drive me crazy. Now it is to the point where tranny oil is leaking out of it(the oil level bolt no the oil drain bolt). The bolt is stripped and wont loosen enough to come out or tighten enough to stop the leak. How do i get the bolt out?? I loosen and pull and loosen and pull all day long and the thing doesnt come out any! Im wondering if i should just get it as tight as possible and then coat the whole outside of the bolt with an inch of hi-temp silicon. I never use this bolt anyways and its gonna drive me mad.
    please help me, ive gota big ride planned tomorrow and i really wanna go, but if this keeps persisting I dont know if i should or not!
    KaTMandoo
  2. Max Factor
    Max Factor Sponsoring Member
    Oct 18, 2000
    155
    This will definitely work if you give it enough time to fully cure (at least 12 hours if it's fairley warm, pref. 24)
    I had exactly the same problem on my 380 and siliconed around and over the bolt, I rode it like that for 2 months.
    I had to take to cover off and drill the bolt out. Repaired the thread after getting the bolt out with a helicoil and new bolt.
  3. KaTMandoo
    May 16, 2001
    84
    What do you mean by you had to take the cover off?
    KaTMandoo
  4. Jaybird
    Jaybird Apprentice Goon
    Mar 16, 2001
    7,097
    36
    KaTMandoo,
    My 125 has two drain plugs and one check plug. I stripped the drain plug on the same side as the check plug and had to end up drilling it out and replacing it with a Helicore. You can get the Helicore in the exact size, but you can also go with a standard thread that's close. The check bolt that you are speaking of is a little harder to get to than the drain plug, so it may be harder to do without breaking your case apart. I think you can get it done though...just be sure that when you drill out the hole, you have the bike leaned over so gravity helps the shavings fall out and not in. Also, fill the flutes of the drill bit with grease so it can help catch the shavings. Grease the flutes of the tap as well. If you use a Helicore, be sure you either get the 'tang' out after placing it in, or be sure it is bent enough so your bolt won't knock it off when you thread it in. If you do loose the tang in the case, I'd suggest going after it if you can. Maybe a flashlight and a magnet stick. Also, use a couple of quarts of ATF to flush out the case after you are done. I like to fill it and watch it come out with a flashlight till I see no more metal comming out.
    BTW...as an afterthought, if you use a bolt that isn't long enough to reach the tang, then you won't have to worry about it. LOL...and don't ask what the tang is until you buy a Helicore kit. :)
  5. KTM Mike
    KTM Mike Subscriber Mi. Trail Riders
    Apr 9, 2001
    2,087
    whew - i feel much better now knowing others have had the same thing happen! So far mine only weeps a bit of oil - but not bad enough to worry about. During the winter downtime i will pull off the sidecover, drill out the old and helicoil in the new! good to know you are not alone!
  6. pedesktm
    pedesktm Rookie DRN Member
    Jan 6, 2000
    26
    I am on my 2nd KTM and from my experiences with the stripped oil check bolt on the 1st bike, I have never taken the oil check bolt out on the 2nd bike. I just change the oil regularly and put in the predescribed qty. No worries here!!!
    Rick
    99 300 EXC
  7. ID 360mxc
    ID 360mxc Rookie DRN Member
    Feb 24, 2001
    I had the same thing happen on my 97 360. I drilled a hole all the way throught the bolt and tapped it to 1/4''.I put grease on the bit and the tap and ran the bike and drained the oil.As for the oil level plug I cleaned around it and JB welded it.I used a short 1/4'' bolt and a small copper crush washer.:)
  8. CrazyTed
    CrazyTed Rookie DRN Member
    Jul 26, 1999
    44
    My 98 250 also stripped the oil level bolt. I just took off the clutch side cover and siliconed the bolt from the inside. Now I just put in the recommended cc's of oil and forget about it....
Similar Threads: dern level
Forum Title Date
Big Bikes Modern 2 strokes vs Classics? Oct 23, 2010
Big Bikes Possible to fit a more modern fork/clamp setup? Aug 26, 2007
Big Bikes Vintage engine & modern YZ125 chassis ? Sep 23, 2006
Big Bikes Modern Carb's-Keihin PWK Jan 3, 2006
Big Bikes modern additions Apr 20, 2004
Share This Page
