Transmission problems kdx200 H model
DonGood
5
Hi all, I bought a KDX200 recently, bike was not running at the time. Got the motor running only to discover that the bike does not have gears above 3rd.
Yet when the bike is not running one can shift through all the gears???? Start her up and she flies off 1st,2nd and then 3rd and no more just nothing there. Opened and removed clutch to investigate, found that the shift shaft was bent, replaced it. Bike selects gears but makes grinding noise, kill switch ammediately. Tear cases apart dont know what im looking at. Took gears to a mech. says the dogs are worn on 4 of the gears? Now my question is can one undercut the gears so that they will engage??? Shift forks also look worn, replacing all 3. Any suggestions on under cutting?
