PLEASE SUPPORT DIRTRIDER
Help cover the site's expences for
our 21st year online!
$1, $5, it all helps!
What flywheel weight for a '01 KTM M/XC 400?
Last weekend while I was riding my new scoot I stalled the bike twice while going through some technical stuff, which wasn't a real big problem since I have that e-button & just hit it while I was still rolling, but I would like to add a flywheel weight to it so this stops happening but I don't know what size to buy. Anybody have any suggestions or experiencing the same problem?
Thanks!
'01 KTM M/XC400 (My bike)
'00 Yamaha TTR225 (My old lead sled, but new night rider/camp hopper & pit vehicle)
'00 Honda CR250 (Hubby's bike)
AMA D37
jeb
I don't know if anyone makes a FWW for the KTM thumpers. I hadn't heard anyone ask so far.
I'd suggest trying:
-Turn up the idle speed a bit
-Adjust the rear brake pedal and/or engagement point down
-Get used to the brakes if this is your first newer KTM
-Change your gearing. What gearing are you running and what kind of terrain?
John Brunsgaard - JEB
01 KTM 400 EXC, 99 KTM 250 EXC, 99 KTM 200 EXC, 98 KTM 125 EXC, 98 KTM 380 MXC (gone)
96 KDX 200
jeb, thanks for the pointers. I will try turning up the idle speed first since this seems to be the easiest thing. I am still getting used to the brakes since this is my first KTM and I was riding a TTR225 before that had really poor brakes. I am currently running the stock gearing, I have only had the bike about three weeks now. I don't have problems with the bike stalling while riding in normal desert terrain, (sand, whoops, etc.)it stalled when I was going slow down hills.
AMA D37
knobbiethrower
Lifetime Sponsor
I think adjusting your brake pedal height and increasing idle speed will cure the stalling.Rear brake has tendency to lock up on downhills going slow.
Y2K KTM 520EXC, Ride Hard and Often!
Shaw520
#5
KTMster, I see you are running stock sprockets,(14/48or50).
At slow speeds this gearing will require alot of clutch play to keep it from stalling. I would first try a 52 or 53 rear sprocket. It makes a big difference.
[This message has been edited by Shaw520 (edited 04-12-2001).]
- a d v e r t i s e m e n t -
Shaw520: You are right, it has taken a lot of cluth play to keep it from stalling when going at a slow pace & then still stalled. I will try a 52 or 53 rear sprocket.
On another note, if you are on a KTM520, I don't know what you do with all that power. Out of hundreds (plural) dez racers, I think I have only seen possibly two to three KTM 520s. That is one FAST bike! Be careful. I don't think I'll ever get my little 400 out of 5th, much less 6th.
AMA D37
[This message has been edited by KTMster (edited 04-12-2001).]
Shaw520
#7
Ya just have to make sure that when you turn it on,.....ya got a place to go!!!
[This message has been edited by Shaw520 (edited 04-13-2001).]
