flyfishdoc
126
Looking at at 1999 YZ 125. Clymers states that the starting engine serial number is 5ET1..... for that year. This bike starts with engine serial number EE.... on the plate behind the kick starter. It is a pro circuit mod engine. What does this bikes serial number indicate ???
The current serial number doesn't match up to anything I have checked in Clymers back to 1994, is it a pro circuit number or something stamped on the case ? Thanks for helping this novice out with any info!
bclapham
4,340
get the vin numbers from the frame, i think the 8th digit can be decoded for years. some one on here will happily run the numbers to ensure it is kosha!
a454elk
Mexicutioner
7,538
18
The 10th digit on the Vin denotes the year and on Yamahas, the last 6 digits or so on the engine match the last ones on the Vin. Post the Vin and the engine number and I can decode it for you.
Elk
a454elk
Mexicutioner
7,538
18
And you're a Chemist!!??:p:p Don't ask why the mixture blew up!!:):)
a454elk
Mexicutioner
7,538
18
That Vin is no good, recalculate and reply! No bueno on the engine either. The only Vin that was close to what you have is this: JYACE03CXXA008675. I can see where this is going :scream:
flyfishdoc
126
I will check when I get home. I am sure about the engine but could have made a booboo on the VIN aas it was 2am when I checked. What do you suspect, is the bike hot or just salvaged bits and pieces???
a454elk
Mexicutioner
7,538
18
Jury is still out......:think: Get back with the info and we talk more.
a454elk
Mexicutioner
7,538
18
Now you have it right now, and yes, the 9th digit is a "0". I'll check some more.........
a454elk
Mexicutioner
7,538
18
:moon: :moon: :):)
a454elk
Mexicutioner
7,538
18
Now you show it as ...008765 not ...008675. By God man, which is it!
bclapham
4,340
its almost like serial number jeapoardy!
dont ever let fishdoc do the ordering at MickyD's, can you imagine the confusion!
flyfishdoc
126
OO8765. That is what happens when the only time I have to work on the bike is between midnite and dawn... Yep, with my five kids the MickeyDs window is a trip. Thanks!!!
jlr425
i have an 83' yz 250 that has serial number on the case and the steering head. The number is 24y-002093. That is it how do i check for a vin with a number like that?
Zrt1200
4
This should help you guys out.
Yamaha YZ Vin Numbers. Use 10th digit
1980 = A 1981 = B 1982 = C 1983 = D 1984 = E 1985 = F
1986 = G 1987 = H 1988 = J 1989 = K 1990 = L 1991 = M
1992 = N 1993 = P 1994 = R 1995 = S 1996 = T 1997 = V
1998 = W 1999 = X 2000 = Y 2001 = 1 2002 = 2 2003 = 3
2004 = 4 2005 = 5 2006 = 6 2007 = 7 2008 = 8 2009 = 9
2010 = A 2011 = B 2012 = C 2013 = D 2014 = E 2015 = F
2016 = G
Year Model Frame # Engine #
1974 YZ250 431-00XXXX 431-000101
1975 YZ250 483-00XXXX 483-000101
1976 YZ250 509-00XXXX 509-100101
1977 YZ250 1W3-00XXXX 1W3-000101
1978 YZ250 2KY-00XXXX 2K7-000101
1979 YZ250 2X4-00XXXX 2X4-000101
1980 YZ250 3R4-00XXXX 3R4-000101
1981 YZ250 4V3-00XXXX 4V3-000101
1982 YZ250 5X5-00XXXX 5X5-000101
1983 YZ250 24Y-00XXXX 24Y-000101 OR 24Y
1984 YZ250 JYA39X007EA00XXXX 39X-000101 OR 43N
1985 YZ250 JYA56A 56A-00
1986 YZ250 JYA1LU 1LU-00
1987 YZ250 JYA2HH 2HH-00
1988 YZ250 JYA2VM 2VM-00
1989 YZ250 JYA3JEWC8KA00XXXX 3JE-00
1990 YZ250 JYA3SPWOXLA00XXXX 3SP-00
1991 YZ250 JYA3XK 3XK-00
1992 YZ250 JYA4DAW01NA00XXXX 4DA-00
1993 YZ250 JYA4EWW00PA01XXXX 4EW-00
1994 YZ250 JYA4JXW03RA01XXXX 4JX-00
1995 YZ250 JYA4ESW05SA00XXXX 4MX-00
1996 YZ250 JYA4SRW0XTA00XXXX 4SR-00
1997 YZ250 JYA4XLW07VA00XXXX 4XL-00 G101E-00XXXX
1998 YZ250 JYACH02W0WA00XXXX 4XL-00 98 G101E-00XXXX
1999 YZ250 JYACG05CXXA00XXXX 5CU-00 G103E-00XXXX
2000 YZ250 JYACG08C2YA01XXXX 5HC-00 G105E-01XXXX
2001 YZ250 JYACG08C11A01XXXX 5MW-00 G105E-0-----
2002 YZ250 JYACE09C52A00XXXX 5NX-00 G106E-00XXXX
2003 YZ250 5UP-00 G108E-00####
2004 YZ250 5PA-00
2005 YZ250 JYACG20C55A00XXXX G111E-00XXXX
