RECENT POSTS
yz125 gear oil
So its time to change my oil. Does anyone have any suggestions on what type of oil to use, or which one is the best?
FNG
I have tried Gear Saver, ATF and then I got my hands on a service manual and they recommended 10W40 motorcycle oil.
I like the 10W40 because I get less false neutrals than the other oils and the shifting action is much smoother.
So I would say run what the manufacturer recommends. If you don't like it, then try some of the others until you get one that YOU like. They all will do their job, and none of them will destroy your tranny so experiment.
I use Bel-Ray gear saver and it works just fine it is just a little thicker tho. I have never had a problem with it.
i use 10w-40 its all good
Matt90GT said:
i run the Honda HP tranny oil in all my bikes
The honda HP oil is good. I have run it in all my bikes at one time or another. I have a sneaking suspicion it's just re-badged ATF though. Same color, same smell, and the clutch/shifting action feels the same between the two. My clutch is wearing, and 10w40 makes the shifting feel overly "notchy". Seems no matter what I try, I always go back to ATF Type F.
I just changed to ATF, type F. Works great. I won't be buying expensive gear oil ever again.
ellandoh
dismount art student
2.59$ a quart makes it easy on the wallet when you change it every ride also :cool:
