steve125
- Oct 19, 2000
- 1,252
- 0
I have my base set up for the 02 cr125.....carby....350-360m..std00yz125needle..3rd clip...25..pilot...1.5..as....(for colder weather 60-50.....30..pilot...same needle but 1 richer straight section)....reeds..delta 2...with opened and matching manifold......cylinder....tighten piston to cylinder clearance with a wiesco piston....1.5 thou....std is 2.5 thou....very noisy! stock.......port timing is quite advanced so the only changes at this time......lower cylinder .010 for more compression and tighter squish ( 200 psi pvs open..... .85mm squish measured)........pipe....for best short course.....00 pc pipe and short silencer (you must use 02 silencers to fit subframe correctly).....long course or prefer top end power is the 02 pc pipe...long or short sliencer.....gearing..13..52 dry course......13..53....lots of traction.......Oh and the pv mod spacer of 7mm diameter.......with these mods you can pick the power you like and it's a huge improvement over stock!!!!!!!...... I prefer the mini 250 feel of the 00 pc pipe....its a good compliment to the delta that helps top..........right now with these mods the bike just rips!!!!!!......now with this base we will go with the 2mm over for even more......:cool:
