coobeans
29
kx 250 performance advice..
ok. so im looking to throw on a few hop ups.. looking at buying a aftermarket exhaust, the low end torque is fine.
im looking for more mid range and top end pull.. So...
Whats a good aftermarket exhaust?
also has anyone ran a 48 in the rear instead of the stock 49 tooth? if so how does it perform?
TWRT
249
I can't give any info on engine hop ups.
But,
make sure the engine is running the best it can.
Top end in good shape
reed valves new (2 stage work good)
no air leaks
jetted properly, running clean
muffler repacked
pipe cleaned
others??
after that my first improvement is the suspension. rebuilt and revalved (resprung if necessary). If this has not been done, then spend the money and use a good shop with high praise.
just my view.
dave
coobeans
29
well, its basically in show room condition. all stock and clean. i bought it form my boss
who got it new and only put like 20 hours on it..i need to adjust the suspension and make it more plush still..and ive heard bad info on procircuit pipes
coobeans
29
Power wise for the kx.. i heard the fatty leaves teh bottom end the same.. but increases mid-top.. so ive found the right pipe.. thanks
