'03 yz250 torque spec??
my manual states two different specs to tighten swingarm bolt....don't know if it's a mis-print or what, but can someone gimme the correct amount to tighten it? thanx in advance!
Just for some info, and to help you a little my manual ('01 YZ250) says 58 ft. lbs. I know it coulda changed over the 2 years, but...
What does your manual say ?
slideways11
mine gives two spec's also one is newton meters and one is foot pounds. Most torque wreches are calibrated both ways just make sure you are using the right spec and the right scale.
Yea, thats true. Maybe you were just looking at the numbers. My manual gives 3 different units which are: ft. lbs., newton-meters, and m-kg.
