Replace the stock water pump shaft with a Boyensen unit. Our '03 came jetted fat on the bottom and too lean on top. We went one size smaller on the pilot and up one size on the main. Make sure you loctite the sprocket bolts! Also, dissasemble the linkage arms, swingarm and steering stem to grease the bearings.
