Help!
Searched for threads on removing a shifter seal ... comes up empty ... amazes me because there is a great post on changing a counter sprocket seal which is dead easy to do because you can get a tool like a spring puller behind the seal to pull it out ... ... nothing on how to get out a shifter seal which doesn't have such an advantage.
I am at my wits end this afternoon ... had a leaking counter shaft seal which I replaced in less than 15 minutes ... opted to replace the shifter seal while I had things apart ... that turned out to be a major headache and mistake since it wasn't leaking! I have tried several tools to pry that bugger out ... in the process, destroying the seal on the two easy sides to attack ... no joy!
Called Lansing Cycle and the gentleman at the parts desk said they sometimes have to drill a small hole in the seal and insert a dry wall screw to give a means for extraction. I am a bit worried about this approach ... not much clearance between the shifter shaft and the wall of the case ... a mistake with either the drill or the screw could result in messing up either of the sealing surfaces. Anyway, I don't have much of the original surface of the seal left to try this technique due to my "inappropriate attempts" thus far.
Any suggestions, tricks or tools on getting a stuck shifter seal out?
Thanks ... terry nestrick
