Wenons
Hey.
Problem with the dirtbike is that it bogs out when full gas, and starts to "bang". When going fast throttle it just bogs.
Ive put so far, new fuel filter , new carb, new air filter, checked all the bolts where it could be loose.
Ive also changed the piston.
Checked the Valves also.
Where could be problem? Float is okay also, changed cam timing also, looks ok, has power.
Wenons
EDIT:
Fixed it.
New Carb didnt solve problem, the problem was loose connection to ignition coil what caused spark to be intermident at higher rpm.
