scottiedawg66
75
hey folks, i siezed my crank / rod at sand mt. a while back running a paddle tire on my yz125. I only weigh 150 lbs and siezed it coming down a HUGE ass dune with 0 throttle...so i think it was my bad. any ways whats the consensus about 125s in the sand, and should i try without a paddle tire?
~scott
KX02
781
The 0 throttle could have been the problem. The engine could have been starved for fuel/oil. Running richer jetting would be good insurance too.
dante101
21
~scott
he is right, because the engine is not getting the normal cooling and stuff it gets from actually moving very fast... that real wheel just spins, and the revs just keep spiking, and your hardley moving, or are trying to stay on it, to make it up something.. i think 125's suck in the sand...
scottiedawg66
75
yes, i agree with u kdx crazy, however i was running my standard jet for sea level, and sand mt. is at over 4000 feet so i figured id already be rich as hell. I think the fact that i wasnt on the throttle was my problem. Whats the consensus with running a 125 in the sand, most of the people i ride with say that they see 125s sieze in the sand often, but since im so light i figued i could get away with it?
~scott
mongial
81
Sand is rough on motors, chains, fork seals....you name it. You might want to check your air filter, boots on both sides of the carb and make sure you weren't sucking air/dirt in the cylinder.
nsxxtreme
125
My GF rides here CR80 in the sand. If she stays in the power band the bike does ok. If she tries to putt it will overheat. I'm surprised you didn't get a warning like the bike blowing water.
When her bike overheated it spit water all over the place.
I let the bike cool down then got her up the hill she was having a problem with.
bikepilot
804
I've run a YZ125 in the dunes at little sahara with no issues. I suspect your problems were more due to riding down the dune at zero throttle than the fact it was a dune, a steep mountian trail would have done the same. When the throttle is closed on a 2-stroke its getting almost no lubrication. There will be quite a bit of residual oil to keep things working for a while, but a really long steep down hill can cause problems. Either put it in neutral or try a bit of throttle next time, be sure your jetting is decent or a bit on the rich side and have fun.
Stick with the paddle tire, a knobby in the sand will suck more power for the same amount of foward thrust. A 6 or 8 paddle is best for a 125.
