14mm threaded mandrel for cylinder heads???
bclapham
4,340
eric put a link up ages ago, but heaven knows where it is- try doing a search on squish or similar head terms and it might find it. maybe in erics forum also?
jman.
They are very easy to make. Take an old spark plug and break the porcelain
part off of it leaving the metal housing with the threads. Then weld a 3/4" diameter piece of bar stock to it.
Be sure to use eye protection when breaking off the porcelain.
Good luck. :thumb:
Jman271
317
Ol'89er, I need this to be true as is will be spinning on a lathe @ about 1200rpm. I will check around a bit, thanks for the hot tip though,,,
cujet
826
5
They are available from various high performance shops. I will try to get some info.
Chris
EricGorr
Super Power AssClown
Aug 24, 2000
708
Jman, I use the Goodson tool, its great deal for under $25. Off-set plug heads have to be fastened to a faceplate because there is no commercial tool available for those types of heads.
