jkrau1207
5
Hi guys, I am new on here and was wondering if anyone knew how much oil I put in the crank case of a 1979 yz 125 2 stroke. Please any info would be appreciated.
John
arnego2
271
In the newer ones I believe its 750ml. is it not printed up on the clutch cover somewhere?
A manual could and should have the info you need
pesky nz
296
You will probably find a level screw on the front of the clutch cover near the end of the crank (the only screw not on the edge of the cover) and after you put in your 650 cc or 0.65 of a litre you sit your bike upright and level and should get a few drips out the level hole. If none comes out you may need to add 50 ccand let the extra dribble out.
pesky nz
296
your welcome, I had an F model that had a DT175 motor fitted, got some good enduro results on it in about 1980 (wish I was that young now)
