The more specific the better. How do you know it isnt getting gas? Does fuel flow from the petcock? Any leaks in carb boot? Fesh air filter? When's the last time it ran?
THE PLUG DOES NOT GET WET, NO LEAKS ECEPT OUT OF OVERFLOW, PETCOCK IS CLEAR, AWEEK AGO IT RAN LIKE USUAL THEN PUTTERED OUT, IT NEVER RAN AGAIN. REPLACED HEAD AND CYLYNDER GASKETS,NEW PET **** NEW AIR FILTER, NEW PLUG.NEW POINTS AND CONDENCER..... VERY CONFUSED.........
possible the float is sticking inside the bowl. or else the needle valve is sticking. also the main jet could be clogged.
Also I had a weird one where the slide was stuck 1/2 way up. couldn't get it to start and the plug was not wet. when I put the slide down it created enough suction to pull fuel in the cylinder again.
