tylerelias
16
what is the float? it will start fine and everything but then i will like take it for a little rip and i'll come to a stop and it'll just die.
sixds
779
i had a problem with an old bike of mine. let it warm up thoroughly for about 3-5 minutes then go. is it fouling a plug?
76GMC1500
Uhhh...
You take it for a little rip and it dies when you come to a stop? As in the bike doesn't idle? Does it start right up after it stops?
The float maintains the fuel level in the carburetor. If for some reason it's not opening all of the way (stuck or out of adjustment), the fuel level could drop slowly as you ride the bike and the bike may eventually die (run out of gas). The bike would be a little hard to start for a while after it died, until the bowl filled again.
76GMC1500
Uhhh...
It's not fouling the plug if it starts right up again. It sounds like it's just not idling. If you keep revving it when you come to a stop does it still die?
Patman
Pantless Wonder
Picup a service manual for your bike, it will help A LOT in understanding what the pieces are and basic trouble shooting & maintenance.
tylerelias
16
well i took off the carb and opened er up and it looks clean. and the float isn't stuck or anything. so i'll put it back on and i'm gettin a new plug and air filter as well so i guess we'll see how it goes.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Looks? don't go by that, clean it..
76GMC1500
Uhhh...
From what I gather, everything is working normally. You're just not used to the short idle period of a 2-stroke. You can adjust some things on the carburetor to make the bike idle for longer, but the best throttle respons and best resistance to fouling plugs is with the carb set to idle for only a second or two after you let off the gas.
76GMC1500
Uhhh...
If the black choke knob is adjustable, use that to bring it down (clockwise). Otherwise, there will be a screw near the center of the carb on the side (counter clockwise). That could be it. You might need to make some adjustments on the pilot screw to restore the throttle response, near the seperation of the float bowl/carb main body on the airbox side. 1 1/2 turns is a good start, if you can't get it right with plus or minus a turn, you'll have to change the pilot jet. For the pilot screw, counterclockwise is leaner, clockwise is richer. I don't know exactly what carb is on the bike, so things may be different, but this covers most carbs on 2-strokes.
If nothing you do controls the idle or the bike is slow to return to idle after a rev, the pilot jet may be too lean or there is an air leak.
76GMC1500
Uhhh...
All that idling may have fouled the plug.
What is your startup procedure? On a 2-stroke, if the choke is off, you've got to roll on the gas a little as you kick it.
tylerelias
16
yea thats how i start it.
what kind of spark plug should i use for my bike? its an 81, i just figured that out when i went to get a new air filter and the 81 needs a cylinder type.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Reeds are what prevent pressure from the crank case from backing up into the carb.
They are in the block between the carb and crank case.
