1982 cr125
NJcr125
7
1982 cr125 help
just got my bike yesterday and motor is locked up the bike ran wen parked its got rust and stuff in the head and around the crank how can i free it up thanks :bang:
Porkchop
341
Pull the spark plug out, turn your bike upside down & drain all the water out of the motor, get it right side up again & pour some atf or diesel fuel in the plug hole,rinse, drain, repeat, until all the rust & smut is gone, with the bike on a stand, put the trans in high gear & rotate the rear wheel, back & forth. It may free up & spin, but I doubt that it will start or run for long if it does. Tear it apart & re-build it, or buy an other motor on ebay or a bike salvage Co.
NJcr125
7
i already took cylinder off i can see all the gunk on top of the crank so put up side down and pour gas in it
Porkchop
341
Gas is a dangerous solvent, it will work but it's flash point temp is dangerously low. One static spark, that is not even visible to the naked eye, can cause a flash fire. I prefer to use diesel or kerosine as a solvent, it's cheap, has a high flashpoint @ room temp & easy to responsibly dispose of with waste used engine oil for recycling.
Porkchop
341
If it's rusted up bad enough to lock up the crank, it may free up but the damage has been done. If you choose to run it, it's only a mater of time before it self destructs.
Read "03 yz 250ssssss" for the next scenario, strange noises...BOOM!
Porkchop
341
All 125's are rev monsters. They're light & run good if everything is mechanically sound. If not, you're spending $ & wrenching on it, or learning how to, or you're walking.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
