I'm having a problem with the bike loading up at lower rpms causing a bogg cond. Opening it up clears it out. Are there adjustment that i can make to the carb to correct this problem?
Had the same problem with my 1989 rm250 took off the carb took out the jets took out the needle vavle found alittle peice of dirt on it now it runs awesome pops up every gear.
