Probably strpped your third gear, your not in neutral, Its just not engaging cause the gear is worn/destroyed. Looks like you will need a bottom end rebuild :(
the bike will go into 4th. Maybe a fork is bent. I will take it apart with a buddy of mine. Hopefully nothing else is wrong, but once you start where does it end.
You'll have to check it out. Obviously, start with the shifting linkage under the right side of the engine cover. Sometimes, it's a simple fix. If it's not there, probably have to split the cases.
