donahue_85
- Jan 31, 2013
- 2
- 0
Ok, here is what I've done thus far, needless to say without results.
1. Replaced right side crank seal
2. Corrected powervalve to proper place & ensured operational movement
3. Oil change
4. New spark plug (NGK BR8EG)
5. Checked spark
6. Checked reeds (brand new)
7. Replaced intake/reed gasket
8. Adjusted air/fuel mixture screw
9. Played with idle
10. Cleaned carburator (about 10x)
11. Added fresh fuel
I have done all these things & nothing seems to have made any difference in the performance of the bike!!! I have hit a brick wall here. :bang: PLEASE offer any advice!!!!!!!!! I want to start with simple things & then move on to the tough stuff.
I have not done a compression check on this bike yet, but either way, it should still run, idle & hit high RPM's, even with low compression. I know this much. I have also not messed with any jetting aside from cleaning them a ton of times.
It is acting as if it hits a rev limiter. After 1/4 throttle, it starts to bog & smoke heavily, like its running too rich. I mix the fuel at 32:1 as recommended. it goes, brrrrrrrrum, bum bum bum bum bum bum. Like if you hold down the gas pedal all the way in your car. It is acting like that. HELP!!!!!!!!!!!!!!!!!!!!!!! :yikes: :( :yikes:
3. Oil change
5. Checked spark
9. Played with idle
