M Matt90GT Member May 3, 2002 1,517 1 May 19, 2002 #1 What is the recommended? Is it 10-30? A friend put 10-30 in there and the bike would not shift. He is using the Honda fluid. That is suppose to be the same stuff in the bike I just got. Could you use synthetic ATF in it?
S spanky250 Mod Ban Dec 10, 2000 1,490 1 May 19, 2002 #2 The recommended lube is 85W gear oil. I use ATF type F in mine.
I Inthewoods Member Apr 1, 2002 33 0 May 19, 2002 #3 I ride a 94 KDX 250 and use 75W gear oil, it seems to shift almost to easy so I agree with spanky250, use 85W.
G gooby Member Nov 8, 2001 497 0 May 19, 2002 #6 listen to spanky250 i switched to atf on his advise glad i did
