1992 Kx250 Forks
CaptainObvious
Formally known as RV6Junkie
3,331
Do you have the upper and lower triple clamps from the KX? If so, yes, you can make them fit. You will need to change the bearings and steering shaft to be compatible with the KDX. It just take a little machining.
If you don’t have the triple clamps there really isn’t any chance of getting them to fit as the KX forks are USD.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
