I need to replace the dogbone bearing where the shock connects. Can I get this at a bearing shop or do I have to go to Suzuki ($$$). Also, do you know the bearing spec's.
Placelast - the spring is GREAT. The front end is much more stable, and the rear hooks up much better. Traction on hills seems much better also. I guess the rear end doesn't squat when climbing anymore. I can actually steer while climbing - what a concept. Thanks again.
Brian
P.S. - I never heard back from you to find out if you got the spring and money order.
