Jun 23, 2009
i have a 95 yz 250 just had the top end bored .080 over my main jet was a 180 at .040 over what should i change my jet too? plugs a grey color when i pull it out and when it cools down it turns to a grayish-black. i was running it at 50:1 but changed to 40:1
FNG
97
I have a stock bore 1995 with a RAD valve and I run a 170 main in MN @ 900ft elevation. I run 32-1 mixing 30% 110 octane with 92 oxy.
Seems to like it, good plug color and wash on the dome.
.040 more will not require a change in jetting IMO.
Jun 23, 2009
i also noticed that it runs pretty hot even if im only on it for a couple minutes. do these things run really hot. and how would i know if the water pump isnt working
FNG
97
Your water pump drive gear may be toast. It is not easy to see and harder to replace. Mine was veryworn out and missing many teeth.
Mine ran hot until I replaced it. Now it is much cooler running and seems to run like it should temp wise.
