OldTimer
475
After setting up for a year, I took out the old Husky for one last spin before I put her up for sale. I quickly discovered that that all the brake fluid had leaked out of the front brake master cylinder and refilled same. The problem is that it won't pump up so as I can bleed it. Apparently the seals and such have dry rotted whilst setting there dry.
My question is where to find a rebuild kit? I suspect that, as many of the Husky parts are, the master cylinder is an "off the shelf" generic type part and I could track down a kit if I only knew the manufacturer or a different bike which uses the type master cylinder.
Any ideas?
OldTimer
475
FYI - It turns out that it's a Brembo master cylinder.
The same one that's used by KTM up to 1999. :cool:
Now I just hope I can find the rebuild kit.
