sharky243
246
Hello, I am restoring one of my old race bikes, a 1996 yz 250. It has a GYT-R long rod kit installed. I want to replace the connecting rod. Some one posted a awhile ago that they used the rod from the 1989 yz 250, is this a fact ? does anyone have the specs for the 89' rod ?
jsantapau
340
yes its an 89 yz 250 rod the only difference between an 89 rod and the 90 to 97?98? rod is that the 89 rod is 130mm center to center compard to the later rod which is 125 mm center to center
sharky243
246
thanks for the info. I should be safe ordering an 89' rod given it is 5mm longer which is the thickness of the spacer plate used to raise the cylinder. Thanks again !!!
