This bike is begining to aggrivate me. I bought in in pieces. I have rebuilt both top and bottom end. I have cleaned the carb and did everything for the first start and ride. I noticed when I bought it a fairly major dent in the pipe, something like the person before hit a pole or something hard enough to bend the rim and dent the pipe. Well anyway, I kick the bike and it starts right up. Put it in gear and try to go, it doesnt go. it has barely enough power to lug itself around. you can shift through the gears and get some speed built up. But thats it. Feels lean, spits and chugs like a seriosly lean bike does. Tried changing timing because Ive had a simular problem on a different bike. nothing. changed jetting, it had a 42/152, put a 165 main in it. Made no difference. Changed spark plug, hotter, no difference. I Pulled the plug it looked brown, a little dark but brown. does it have something to do with the dent in the pipe or is it the carb still?
