Well, my old 96 CR250 is starting to get some pretty good vibration going on, so I think it may be time to tear it down and rebuild. I've personally rode it for 3 years now, the last year or two pretty hard. I've put a few pistons , but have never done a bottom end before. I've split cases before, so that really doesn't bother me. I feel I have the mechanical ability to do the job.
My question here is, what all should I replace when I'm in there. So far I have all of the seals, a new rod and rod bearings as well as a piston, rings and top end bearing. Is there anything else? My worst fear is doing all of this work, then having to go back into it because I didn't replace one item.
Also, what do I need to do to the crank before installing the new rod/bearing? Should I have it Mic'd to see if it needs turned or anything?
I appreciate any advise or suggestions.
deano...
deano...
