Hi everyone. This post refers to the porting diagram for a 2000 Honda CR125 from Eric Gorr's Performace Handbook. First when it says to lower the outer edges of the exhaust port 8mm, it shows a drawing that shows cutting down the lower edge of the port, but it does not say how deep, only how long to cut. Second, When it says re-profile the exhaust valve 2mm, is that keeping the same radius as stock, just removing 2mm of material? Third, aside from raising the exhaust port to 27.5mm from the top of the cylinder, would rasing the transfer ports 0.5 to 1.0 mm serve to add more top end while keeping a good amount of rideability, or would they take off too much bottom? My final question is with these mods, would a Wiseco 707PS (no intake window) piston help regain some of the lost low-end, while still providing favorable power characteristics on top?
Thanks,
Matt
