The motor has been completely rebuilt by Eric Gorr and I can't say enough about how nice of a job he had done. The only problem i'm still having is it tends to overheat while riding in tight woods trails. Coolant starts to come out of overflow when riding tight woods trails with hills. Could it be that some of the cores in my radiators are pluged? I use 50/50 coolant/non-tap water mixture. Should I also consider removing the plastic radiator gaurds and replacing them with an aftermarket type of guard to help increase airflow thru radiators? Any recommendations on coolant that might also help. I'm currently using Prestone and it contains no silicates. Any help would be great! Thanks... :thumb:
