2000 suzuki 125rm oil
josh125rm
i changed the oil in my 125 yesterday and took it out and it blew up ? , i only put a quart in was this too little?
adam728
1,011
A quart is probably a little more than what it requires.
The oil in the lower end only lubricates the clutch and transmission. It would have nothing to do with the motor blowing up. The oil mixed in the gasoline is what lubes the piston/rings/crank etc.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
