I just got done replacing my clutch.
It has a lot of play and to get it tight i had to adjust the thing by the lever to tighten the clutch.But i tightened it quite a bit and i dont like it extended out so much.Anything i did wrong or is it ok?
Next thing i noticed is when i drained to tranny oil there were quite a bit of metal shavings.What does this mean?Im thinking its not the greatest sign.
And the last when i turn off my engine and When i put my bike in gear if i pull back it stops and i rock it again and it goes back ward after a little rocking.I use to ride a crf150 and it never would do that.It would lock up and the tire would not move.
tHANKS FOR THE HELP!!
