hi i just had my cr250 rebuilt with a new top end and i have it jetted fine according to a plug check.... the problem is that theres no bottom end has no power unless its up in the rpm.. ok if im in 3rd gear about 1/2 throttle and jump on the gas it will snap lift right up no problems and thats in every gear 1st thru 5th..... but if u let it get below a certian rpm range and jump on the gas it will spit sputter and hesitate before the power kicks in... like today i was doin some hill climbs 3rd gear ripping right up it but if the front end started to come up and i let off the gas a lil then got on it... it would fall flat on its face any help would be great..... ok about that RC valve is it supose to be moving when the bike is just idleing? i looked at alot of threads on here but none i found realy relate to the same problem im having
