James said:diameter.thickness (quantity)
Passive Compression
PISTON/Valve
20.10 (2)
19.10
18.10
17.10
16.10
15.10
14.10
13.10
12.10
11.10
10.10
9.10
8.20
16.30 (6)
Rebound
PISTON/Valve
20.10 (2)
18.10
12.10
16.10
14.10
13.10
11.20
16.30 (4)
James said:That is the passive compression stack in the fork cap. I didn't put the midvalve in there as it wasn't requested. BUT, it comes stock as follows:
20.10 (3)
17.10 (4)
It has about .5mm of lift I think but I kind of gave up on getting a super accurate measurement. I am tunring the 00 into a hare Scrambles bike this year so I may just pull one of those 17s out and be done with it.
The 02 forks were surprisingly soft for me even with all of those shims. I had to go a bit stiffer than stock. The 00 has a 9mm clamping shim and that made all the difference for me.
James said:25.30
26.30
27.30
28.30
29.30
30.30
32.30
34.30
36.30
38.30
40.30
26.10
40.20
PISTON
44.20(6)
44.15(5)
37.15
30.15
42.20
40.20
38.25
36.25
34.25
32.25
30.25
28.25
26.30
24.30
22.30
30.30(5) - these are just space fillers but will get the nut where it needs to be.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
